thread
- Jan 30, 2007
Someone at my office is trying to sell some audio equipment from his home theater.
I'm not really trying to build a home theater, though. I just want some good 2-channel speaker sound. I've heard good things about these B&W speakers in the past... and I'm thinking that, if he's willing to piecemeal me some stuff, I could get some cheap speakers here.
My question has three parts:
Are these speakers pretty good (accuracy, etc) or can I do a lot better these days?
What does one use to power them? It seems he's using a receiver unit... But my frontend currently is an RPX-33 headphone amp/preamp. I'm wondering if I can use it alone with these speakers? Where does a "power amp" come in?
Finally, what are the good resources for learning good stuff about speakers?
RPX-33 specs:
Maximum Output: 700mW
Output Impedance: 16 - 600 Ohm
Bandwidth: 1-100.000 Hz < 0.5db
Gain: 16 db
THD: 0.02% (3Vpp on 32Ohm)
Technology: FET & Bipolar Transistors
Input Ipmedance: 47 Kohm
Amplification Class: Always A-Class
Input / Output: 1 x line
Dimensions (cm): 350 *60*282 mm
Output: For two headphones
Weight (Kg): 8 kg
http://www.rudistor.com/soundsystems/rpx33.htm
B&W 602 specs:
DM 602 S3 2-driver, 2-way ported-box speaker
Drivers: 1" alloy-dome tweeter,
7" woven-Kevlar bass/midrange cone
Frequency response: 52Hz–20kHz, +/-3dB on reference axis
Frequency range: –6dB @ 43Hz & 30kHz
Harmonic distortion: <1%, 2nd and 3rd harmonics (90dB/m), 60Hz–20kHz
Nominal impedance: 8 ohms (minimum 4ohms)
Crossover frequency: 4kHz
Recommended amplifier power: 25–120W into 8ohms
Sensitivity: 90dB/2.83V/m
http://ultimateavmag.com/speakersyst...BW/index2.html
Thanks!
- 2x B&W 601's
- 2x B&W 602's
- "matching" center channel (model CC6)
- Denon receiver, Marantz DVD player...
- Velodyne HGS 10 BG Subwoofer
RPX-33 specs:
Gain: 16 db
Weight (Kg): 8 kg
B&W 602 specs:
Thanks!
