mvw2
- Feb 9, 2007
Are your choices only IEMs? Or would you be willing to run a bud? I suggest because I too owned a ER4S as part of searching around for my ideal earphone. I actually finally ended up on Yuin's OK1 as the only thing I ran that matched and ultimately bested (for the characteristics I looked for) the ER4S. The OK1 is a remarkably good bud.
Now I haven't run the W3 or UM3X, so I can't comment on those. The ER4S is a very nice earphone, definitely an industry standard type of product. A lot of your choice will come largely down to personal preference. The best way to really decide is to simply buy both. Run both, fiddle with tips, play with EQing, do whatever you're willing to do to modify the sound and improve to your liking. Run the ER4S as the comparator. In the end, one will be the better. It may even still be the ER4S. Whatever you end up liking best, keep, and sell the other two. This is really the only way you can go about doing this without running into that "the other could possibly be better" thought after you try just the one.
