markzi
- Sep 24, 2011
Ok, so first things first, I'm using a desktop with Onboard Sound. No Sound Card. Now, I recently got a pair of Sennheiser HD 598's, and I figured the best solution would be to get a Fiio E7.
Yesterday I started using a program to record my guitar directly into the PC. Anyway, the sound is horrible because I dont have a sound Card, it says on the website that I need a decent sound card to get good sound from it.
A lot of people told me not to get a Sound Card since I will be getting the Fiio E7. They said that the Fiio E7 replaces the sound card.
If I do end up getting a sound card, can I use the Fiio E7 AMP only without DAC so that I combine the power of the soundcard with the Fiio's Amp? Or will the Fiio E7 still replace the Soundcard?
Also, I'm willing to spend about 100$ if it will get me better quality, any suggestions?
