fizzytao
- Oct 20, 2013
Thank you for your confirmation! Still considering to get the N6 Ultra. If so, will sell the M11 Plus LTD.Yes, under the Settings menu, there is the option for either LO or PO.
Thanks. I listen to symphonies and operas and as well string pieces, e.g. Le quattro stagioni or violin pieces. Would you recommend M7 or M6U as the upgrade of my M3X?
Hi could you please confirm if there is line-out setting from the 4.4mm balance out? Just in case would like to connect to an external amp. Thank you ahead!
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
A nice brief review. Thank you! Have you got a chance to compare the 4.4mm LO of the two? I have the M11 Plus LTD, too. I wanna get the M6 Ultra and expect a more punchier bass and a little ‘thicker’ vocal. Do you think it is a valid expectation?Having both Fiio M11 Plus LTD and Shanling M6 Ultra with HifiMan Arya Stealth on balanced (meze silver plated) cable.
Sharing first impressions comparison:
Soundwise M6 Ultra has notably wider soundstage & more detail and slightly better instrument separation. I guess thats the magic of having 2 extra DACs. M6 has also more power, listening Arya on 45/100, while M11 needs 80/120, both on high gain. Otherwise tonality, speed, punch, they are both alike. Both have issues on my old Wifi access points (Cisco 2702) with latest software both on DAPs and on APs. M11 had extremely weak wifi signal, particularly in horizontal position, it was disconnecting often, vertically oriented (back pointing to AP) it was working ok. M6 didnt had signal issues, but reported abysmall internet speeds in same spot same position. Once I replaced my access points with Ubiquity U6 Pro, both players perform great on wifi, achieving around 100Mbps throughput in my regular listening spot and player positioning (2m away from AP, horizontal, top of DAP pointed towards AP).
M6 ultra has much better Bluetooth LDAC TX performance, able to stream to my Fiio BTA30 Pro (for tower speakers) from all around the apartment, while M11 is choppy even within couple of meters.
M6 Ultra (267g) is quite lighter than M11 (302g). Those 35g makes quite a difference.
Both have great build quality, although M11 has a micro sd shelf with tight fit, while M6 has kinda finicky micro sd slot with flimsy plastic cover. I know that 4,4mm balanced is a future, but I like presence of 2,5mm TRRS on M11 as it allows me to use my older balanced cables without adapters.
For the bass and vocals they sound same to me in terms of punch & thickness.A nice brief review. Thank you! Have you got a chance to compare the 4.4mm LO of the two? I have the M11 Plus LTD, too. I wanna get the M6 Ultra and expect a more punchier bass and a little ‘thicker’ vocal. Do you think it is a valid expectation?
Thank you for the feedback! Looks like M6 Ultra needs more work on firmware and drivers.For the bass and vocals they sound same to me in terms of punch & thickness.
Some software issues of M6 Ultra on SW 1.22 & drivers 5.20 in Windows11:
- USB DAC function doesn't work on USB 3.1 Gen2 port. Must be connected to USB 2.0 port (confirmed with 2 different PCs). (Windows11 reports USB device not working)
- When you switch from USB DAC mode to USB Disk mode, then charging sometimes doesn't work afterwards (neither through PC and QC3.0/4.0 charger) until you restart the unit.
- USB Disk mode doesn't work for me at all.
- Device doesn't charge it self when used as USB DAC
- Couple of freezes when using Tidal to explicitly control M6 Ultra. Had to hold power for 12 seconds to force shutdown and same to enable again.
Overall Fiio M11 Plus LTD's software is much more stable and reliable, with much more configurable options (limiting battery maximum charge, etc.) and practical functionalities (like rotating screen by 180 degrees)
Yeah its kind of shame, sounds good, hardware is good, but the software feels almost as some alpha release when it comes to USB interaction with PC. However when used as DAP-only it performs ok in terms of SW stability, although there is some unexplainable delay when you want to bring minimized and playing Tidal back to front.Thank you for the feedback! Looks like M6 Ultra needs more work on firmware and drivers.
However although battery icon shows charging, the battery it self is actually discharging.
- Over the Air update function take ages, freezes multiple times on network error, offered Server2 doesn't work at all. It takes whole day to make this thing update it self, and you cannot download new firmware from EN mutation of Shanling's website either as to use the upgrade from disk option.
Is the firmware that will add Roon support still upcoming?
Thanks for the answers and clarifications.- This is strange, I'm running it from USB 3.0 USB-C connector without issue. Might be issue connected with Windows 11, will check on that.
- We saw few reports of this in connection to the new charging switch in USB DAC mode, investigating on it.
- USB charging is so slow, that it can't keep up with the power demands of M6 Ultra.
- Not sure what exactly you mean by "Explicitly control M6U"? You mean just simply playing Tidal music on your M6U?
- OTA updates is run from our Chinese servers, the speed unfortunately changes from country to country. Download link for M6U firmware is available in news section on our website: https://en.shanling.com/article-EM7M7M6UAugustupdate.html
Right now software team is checking on why the Roon app or Roon ARC are not working.
