puppyfi
- May 29, 2014
Shanling
1. Some manufacturers (Fiio, example), fixed the 5800 tracks bugs without (mentioning) any slow down on system response time. May be the slow down is negligible, same as Fiio (may be why Fiio not mentioning if indeed it is the similar issue affecting all manufacturers)? I think it is worth a try fixing it. May be like nmatheis suggested, let the people try it and see their feedback.
2. I would go with the 44:9 majority.
3. Possible to implement some of the M2 goodies for big brother M3? I owned the M3 and one wish I had was changes to the power on button implementation. It should be press and hold to power on (currently, you just need a light press to power on the unit), just like press and hold to power off.
