cel4145
I hope that I don't get burned on a headphone stand.
No. You'll be publicly electrocuted with speaker taps off an amp.
No. You'll be publicly electrocuted with speaker taps off an amp.![]()
I wonder, do you feel comfortable strapping headphones onto your head that requires over 100 V to drive? :eek: What happens if you sweat?
I haven't even thought about buying electrostatics. I want to substantially upgrade my home audio speaker setup, which requires a lot of money.
But no. I don't really want to strap 110v on my head connected to an amp that could give me shock treatments.![]()
Beyond that it wouldn't be a bad idea to put a resistor in series with one of the amps to isolate loads a bit. Something like at least 100 ohms up to 1k ohms depending on input impedance. Try to stay at leat 20-1 relative to input impedance and even lower values will help. Subtle difference but generally audible and the resistor won't hurt anything except a slight change in gain on whichever amp it's fronting. Ask Shiit about it and see what they think. I'd suspect Mike Moffat would agree though not a huge deal.
I heard a Gungnir the other day. Kinda better than real in a good way, LOL. Mike can still voice things.
You are better off with two amps and a Y cable as they two cans have different impedances and sensitivities, Take a look at the Schiit Magni 2 amp,possibly the Uber option if you find the preamp out useful.
You can get an audio switch to select between the DAC output and the computer output and connect the Y cable to the switch.
And lastly, StanD suggested that I get a Schiit Magni 2. What benefit would I have if I get the Uber model that has a pre-amp? Does it means that I could connect another amp for more volume? Sorry for being a Newbie! :/
That answer mean that you can't accept the truth about human limitations?![]()
These crusades get tedious.
I'm not going to investigate further because my results are real world but consider the nonreactive remark more carefully. I would think considerably less reactive would be more correct with cables, connections, feedback loops etc involved. The opposed thinking is of the same school that believes cables can't sound different. I do, you may not.
