caveman
- Jan 9, 2004
Would somebody lend a hand on best settings for above card please.
I intend using it on an XP PC with audio out using RCA cables to my Rotel amp and MA speakers using Flac files and foobar 8.3.
I have yet to install card but would uninstall drivers for earlier soundcard, but then would it be best to download latest drivers from M-audio site and use them for initial installation or use CD and then update to the latest ones?
BTW is the control panel software part of the same driver file as I can't see a separate file for it's installation.
Following that what are the best settings for the card, purely for audio. If you could manage it what ammendments should I make to foobar?
Sorry for all the questions, I am past my prime with this sort of thing and you guys seem to be the experts. Many thanks in anticipation.
