Osc4r86
I want a to buy a audioengine d1dac and smsl ad18 amplifier so i can hook it up to my mac mini and ps4 is that possible . Like what connections would i need to setup everything or how do i go about putting it together?
I was just checking out the manual online and they stated that the optical takes preference over USB. So hooking up the PS4 would mean that it would be the dominant source. There is no way to switch between the two it seems. I am guessing that you would need to unplug the Optical to get the USB to work.so with the d1 amp/dac i can hook up the mac with the usb cable and with the ps4 i can hook it up with a toslink cable right how do i change with output to use when i have one device on
do u know of any am/dac integrated together or separate that has a remote or switch u can use for switching between connections?I was just checking out the manual online and they stated that the optical takes preference over USB. So hooking up the PS4 would mean that it would be the dominant source. There is no way to switch between the two it seems. I am guessing that you would need to unplug the Optical to get the USB to work.
I know HDVD800 and TA-ZH1ES able to switch around using the control knob.do u know of any am/dac integrated together or separate that has a remote or switch u can use for switching between connections?
on budget here i can muster up to buy the audioengine d1s or wait a little bit and save for fostex hp-a3 they have a button for switching and there made in japanI know HDVD800 and TA-ZH1ES able to switch around using the control knob.
i dont know about the jds labs one but the topping dac and amp look good enough to buy . if i may how would u set it up and what cables would u use for them to work together?Topping D30 DAC + A30 amp, the D30 has a selector switch between optical, coaxial and USB.
The JDS Labs OL DAC would also work, it has a switch on the front to switch between Optical and USB.
so like this rca to rcaSo you need an RCA cable between the D30 and A30.
Then you need the optical out of the playstation into the D30, and the USB output of the Mac Mini into the D30 then just use the selector switch to change between optical and USB.
so like this rca to rca from d30 to a30 and then optical . from the ps4 and usb to the mac mini . do u think it can take a usb 3 male b or a regular usb 2 male b cable?
does it matter if its gold plated or not ? all the cablesThe Topping D30 comes with a USB cable so you don't need to worry about it. It comes with one of these:
k thank u now to order everythingNot at all, the gold plating is just so they don't corrode/oxidise.
