tennisets
I'm selling my RS-1s since they don't really work for my living situation right now because I can't use them when my room mate is sleeping. I'm going to get a pair of high end IEMs instead so that I can use them both portably and at home.
I'm really undecided between the Sensaphonics phones or Westone at this point (not sure about ES2 vs. ES3 either, I sent a PM to digihead about that).
Advantages for Sensa: I live outside of Chicago, so I could get my impressions done at Sensaphonics, which is a plus. They're supposed to be the most comfortable of the IEMs. Disadvantages: lots of people have reported problems with them after about a year, and the silicone may shrink over time. The consensus seems to be that they're not really suited to rock music? Is this in the same vein that Senns are not suited to rock music (IMO)?
Advantages for Westone: Greater durability due to the hard casing. A more exciting sound. Disadvantages: Have to send impressions from an audiologist to Westone, maybe not as high a chance of success on first try as with Sensa. Probably not as comfortable.
Another question: is the "soft" casing that Westone uses similar to what UE used to use that would crack and dry after a while? Here is what is said on their website:
Is that like what UE used? If so it would likely display the same problems, right?
Lastly, there was a flurry of activity around August and September of this year with a lot of members' Sensas shorting out. I haven't seen anything about that issue since then. Have there been any new instances of peoples' Sensas breaking? This is a real concern for me.
Thanks for any advice.
Unlike many of the soft monitors currently available, Westone encases the monitor's sensitive electronics in a hard acrylic inner shell. This keeps these components, vital to the monitor's performance, safe from the often-abusive wear and tear monitors must endure on the road. The hard inner shell is then surrounded in a soft body-temperature reactive skin that is approximately an eighth inch thick. |
