I've never really had headphones that had interchangeable cables before, so I was just wondering if its really a drastic difference when you upgrade the cable? If it is, what is the best bang for the buck as far as HD 650 cables go?
What components do you have the HD650 hooked into? Pouring funds into a cable "upgrade" should be at the very bottom of the list of priorities to get the most out of the HD650.
I was never really a 'cable guy', but once I had replaced the cabling on my HD-600's and HD-650's to Stefan AudioArt Equinox and Cardas (blue smurf) respectively I have noticed a considerable and audible improvement - well worth the investment!
