meridius
- Jan 6, 2008
I just bought a pair of Sennheiser MOMENTUM True Wireless 2 as moved from a pair of westone W4r but wanted some help on the ear tips and EQ settings.
It Seems My left ear feels well sealed with the stock Tips but my right seems a little open i did try the large over the medium tips but the large was just too big and i could not even get a seal. i need something a tiny bit bigger than the medium stock tip but not the same size as the big stock tip so not too sure what to go for.
I used comply for years on the westones w4r but you have to keep replacing them but might still try them out but wanted something maybe better if that's possible. also been looking at the spin fit CP360- M/L but never tried them so not too sure.
also, they need to be able to fit the case.
any help would be great
