LifeAspect
my cable arrived~
thanks custom-cable
thanks custom-cable
my cable arrived~
thanks custom-cable
Does anybody know if Sennheiser has fixed the problem the amplifier had with high definition files? It is a bit pathetic if they have not. I am holding out on a purchase in the hope that Sennheiser will announce a firmware update or a unit recall or something
Perhaps one of the Sennheiser marketing guys who posted in this thread can help us!
Thanks
Pedro
thr the 4th of September is when u can download the update 2 fix the hi res problem.Does anybody know if Sennheiser has fixed the problem the amplifier had with high definition files? It is a bit pathetic if they have not. I am holding out on a purchase in the hope that Sennheiser will announce a firmware update or a unit recall or something
Thanks
Pedro
rsung,
For what it is worth, I can't think of any reason at all that you will not see an improvement with the balanced configuration with the same exact headphone cables.
In any event, If I were in your position, chomping at the bit to hear the differences (and I would be, trust me!) Just have someone competent at working with cables cut the jack off of your existing headphone cable, leaving a short tail of cable 8 to 10 inches on the jack. Then install a 4 pin male XLR on the headphone cable and a 4 pin female XLR on the 8 inch tail to the original 1/4 inch jack using the wiring pinouts documented in the HDVD800 manual. Now you have the ability to use BOTH balanced and unbalanced and it should only cost you 2 XLR connectors ($12-$20 cost total) and the labor to terminate just 2 cables (20-30 minutes total).
Now the adapter will also look the same as the headphone cable (if you are at all concerned with looksIn fact, if you are, make sure that they use the all black Neutrix connectors and not the nickel plated ones).
And you will be able to immediately A-B compare the 1/4 inch jack and XLR outputs of the HDVD800 by simply moving the one male XLR connector on your headphone cable between the XLR connector on the HDVD800 and the XLR connector on your new adaptor (which you just leave plugged into the HDVD800 unbalanced jack all the time)
Easier than what you were planning and you can start on it today instead of waiting for cables to show up. Sennheiser seems to have a long history of getting stuff on the shelves much later than they advertise sometimes. After all, weren't the HDVD800s supposed to have originally been on the selves last September or earlier? They didn't really start showing up until May...
- Jeff
I need to make an additional comment here. There is a very good possibility (I'm looking into it right now) that BOTH the stock headphone cords for the HD800 and the T1 use Litz wire. This stuff is much trickier to work with and if not terminated correctly can degrade your sound. If you are re-terminating a stock HD800 or T1 headphone cable, the person doing so needs to have experience working with fine Litz wire.
Just about to order my HDVD 800's Should I wait for Sennheiser to release their balanced cables? or Should I go ahead and order somethin
