MelvinV
- Jun 19, 2012
There is a easy way, just take the stock HD 800 cable, remove the 1/4" plug and put XLR on there. If you can't do it yourself let some audio store do it for you.
You'll get the same cable that Senn sells for £250, the only difference is that your XLR connector is different.
Is there a 3rd party alternative to this? It is mighty expensive at £250, an outrage even
