kerrys30
- May 30, 2013
You can bypass the internal DAC of HDVD800 by connecting your external DAC through the HDVD800 analogue inputs.
Brilliant - Thanks.
is the main difference between HDVD800 and HDVD600 that 800 has a DAC function? Can the 800 be run as just an amp without using the DAC? Thanks.
I get the HDVD800 = dac + amp and HDVA600 = amp only thing. Certainly the amp specs look identical, but I wonder why '800' vs '600'? Is that just a marketing ploy to make people think the HDVD800 is somehow 'better' than the HDVA600? or is there really some other difference, eg HDVD800 more suited to HD800 cans and HDVA600 more suited to HD600/650's??
Also in balance mode it is only 22 ohms. .
Al
Al
Very happy owner here!
I use the combo HDVD800 + HD800 balanced cable for over a year now. I am wowed every single time that I listen to this combo.
At first I didn't like the HD800 because of the treble peak and the soundstage too large. I tried a lot of gear without great result for my liking (sometime very expensive gear, very well regarded gear with the HD800). Then I try the HDVD800 to my ears solved the two problems brilliantly, and with a crazy sound resolution. I don't want to change anything in my gear. If I want to upgrade, I think the only way is to sell everything and go for a SR009 gear:basshead: ! Until then the HDVD800 makes me heavenly happy. One of the best partner I could find for my HD800.
If you can afford an external DAC I would have bought the HDVD600 and saved the delta cost versus the HDVD800 for music.
The amp is fabulous but the DAC no. Have paired the DAC section with MAcPro or high-specced PC but the music it not very fleshed out, in fact at bit grayish. Also tried to pair the HDVD800 with the USB outlet of the Auralic Aries streamer. Same underwhelming result. Still, the Aries does magic as source for my other DACs ( Ayre QB9 and Weiss DAC202). Having these external DACs feeding the balanced analoge input of the HDVD800 is a totally (better) story ;D
