- Oct 26, 2008
Today I decided to have a listen to the O2/odac combo. It's close ! It's too bloody damn close!
LOL, this is not reassuring
No it's not . Or it is ?! Depends how you see it I suppose.
Maybe the Odac is better than the dac in the HDVD 800, since that is the weakest part in the HDVD 800. I haven't heard the Odac, but as long as it's better than a Xonar Essence ST it should be better than the HDVD 800 dac. Trying to gain some perspective on the Odac I browsed through 30+ pages in the various Odac threads and many reviews and didn't learn anything. The only people buying it seem to be Fiio owners, and I've never heard any of them either. Maybe I'll buy one so I can get an idea of how good it actually is compared to the HDVD 800 dac and the Xonar Essence One Muses Edition.
Really?
Hi guys -
I have a few questions about the HDVD 800 and would be grateful if you would answer them.
1. Can the HDVD 800 be used just as an amplifier in combination with a separate DAC - if I chose to get another DAC, could I then use the HDVD 800 bypassing its DAC and as a standalone analogue amp just like the HDVA 600?
2. For those of you that have many hours of listening experience with the HDVD 800 and HD 800 with stock cable, apart from being a means to hear the smallest details of the music and enjoy them with feeling, do you find that the tone/sound of that combo is conducive to pleasant listening in a relaxed, non-analytical way too?
Thank you.
Have you spend much time comparing the headphone outputs of the Asus vs. the HDVD? I would be interested in hearing your opinions.
I finally got around to comparing the headphone outputs between the Asus Xonar Essence One Muses Edition and HDVD 800. First off I have to say that the Asus is nearly catastrophic from a functional perspective. The gain on the volume knob is crazy. 9 o clock on the Asus volume knob is the same volume as 11 on the Sennheiser. The potentiometer works in notched steps and is also very cheap, so the first three steps you only hear sound from the left channel. This means you have almost no range on the low end to work with before the sound gets really loud. I tried the HD 800 and B&W P5. It was a problem with the HD 800 and it made the P5 unusable with the Asus unless I lowered the volume via software. No wonder Asus have changed the volume knobs on later revisions.
As for the sound I really enjoyed the Asus. It has quite a lot of bass which goes well with the HD 800. Overall the sound seemed a bit peaky and glaring compared to the HDVD 800 amp, but it was subtle enough that it wasn't a problem most of the time. Sometimes a synth with reverb would sound a bit unpleasant, and I'd switch to the HDVD 800 and suddenly it'd sound just fine. At other times there would be some high frequency sound that grated just a tiny bit, and again I'd switch to the HDVD 800 and it'd sound just fine instead. Not serious issues though by any means. The stereo perspective isn't as wide with the Asus, and this was the most obvious difference going between the two amps. I had them volume matched, using the stock unbalanced HD 800 cable, so I could quickly unplug it from the Asus and jam it in the HDVD 800 in 1-2 seconds and hear the same passage at the same volume. Every time I went from the Asus to the Sennheiser the sound became wider and more open. Some subtle instrument always popped out at me as I assume it was being obscured slightly with the Asus. The Asus has a style that's a bit more blaring and in your face, while the HDVD 800 seemed better balanced, more natural and I would say more sophisticated. Several tracks had more physical bass oomph with the Asus, while the Sennheiser instead had more detail in the bass. Like the volume knob it comes with, the Asus has a slightly blunt sound. But it's very likable! It's energetic and fun.
As far as tone, balance and such the HD 800 goes very well with the Xonar Essence Muses Edition amp. The only problem is that the volume knob is a disaster. What kind of headphones did they have in mind when they tweaked the gain? The HDVD 800 knob is perfectly usable with even highly sensitive headphones, while the Asus will blast your ears off if you don't use something like the HD 800.
It sounds like you have an older Essence One with the channel imbalance problem. This was corrected by Asus some time ago... A different volume pot and the addition of gain jumpers.
