rpdugan
- Jul 20, 2005
If I don’t need the DAC, is there any reason sound wise to upgrade from the HDVA 600 to the HDV 620? I use the 800S headphones?
Ur using this with balanced cable ?Just got my HDV820 yesterday. Listened for a couple hours with HD800S. It sounds very good. I must say I was surprised how well my A90/D90 stack kept up. The Senn is definitely better, but man the Topping is pretty impressive based on initial comparison.
A couple of notes: The Senn provides an overall improvement in sound that is hard to describe. It is more three dimensional, Topping stack is wide also but tends to push things in a straight line left to right. The Senn is more 3D, including bringing more height. The Senn is also cleaner, not by much, but it is more articulate - this did surprise me a little since the Topping stack is quite articulate. Senn seems to have tighter bass, and a little more of it then the Topping. Senn also has an overall sound that seems just a touch more unified. Sound stage is still wide but it somehow feels more cohesive. Treble, as with the rest of the sound, is more articulate an seems to permeate across the whole sound signature, which provides that additional clarity.
Will continue to listen this weekend and try different headphones. So far used the HD800S. I have Dan Clark Audio Ether Flow Open 1.1, AKG Q701, and Fostex Th610. Topping unit is the MQA version. Listening to Tidal and purchased an AQ Cinnamon cable for USB connection. I also have a Fostex HP-A4BL that I use DAC into a Bellari HA543 with Gold Lion 12AT7. That is a fuller/warmer sound than the Topping. Will be interesting to bring that into the comparison.
I like the amp, but question is, is it worth $2,400 for improvements to existing system.
Yes, I am using balanced. Also, tried optical. It sounds very good, Topping just keeps up very well. Actually have a Qutest arriving today, I am interested to see what impact that has on the overall sound. I know some have questioned the quality of the DAC, so I will be interested to see how this Qutest impacts overall sound quality.Ur using this with balanced cable ?
Yea I’ve heard the same stuff said about the DAC as well, please do let me know how it is with the Qutest. My dream is tho a high end AIO, hoping it’s not to different. HD800s and HDV820 would be my end game no doubt I think.Yes, I am using balanced. Also, tried optical. It sounds very good, Topping just keeps up very well. Actually have a Qutest arriving today, I am interested to see what impact that has on the overall sound. I know some have questioned the quality of the DAC, so I will be interested to see how this Qutest impacts overall sound quality.
And don't get me wrong, the device is very good and the construction quality is superb. So we will se where we go from here.
Appreciate the write up a lot, very detailed, thank you. Just to be clear, ur using the AQ Cinnamon cable with HDV820 to ur PC? And I’ve never had a balanced AIO, since I’d be using onboard DAC I just plug my balanced HD800s straight in, I don’t need to buy anything else to make it balanced? We have read legit the same stuff on the amp, that the dac wasn’t very good in it even tho it cost quite a bit, and that it didn’t do very good with any other headphones besides the HD800s and HD820. Glad u took the plunge and enjoy it. Did u consider the HD800s and HDV820 pairing as an all-rounder?Qutest sounds just a touch more articulate and with a bit more depth in the sound. Also seems to bring vocals forward a bit. Overall the sound of the HDV820 is darker, but still very articulate. As with most things in this hobby, at this level, differences are subtle, but they are there. What's interesting is that using optical instead of USB with the HDV820 seems to impart a similar quality. In the end, I would say not much in it really but has me thinking about some possible ways of approaching my set up.
Just to add, I think you would be very happy with the HDV820/HD800S combo. I really thought I might send it back because the Topping was quite close. Having heard the Qutest DAC with the HDV820 it becomes even more apparent to me that the HDV820 is really outstanding and most differences at this level will be subtle. I also tried running the D90 DAC into the HDV820, the Sennheiser DAC was better. When you factor in the beautiful build quality of the Sennheiser and the number of inputs and the power of the amplifier, it really is a very compelling setup. Now I am thinking it may be here to stay.
Also, I have other headphones and it works well with them as well, so it isn't just good for the Sennheiser headphones. Hope this helps. I just got tired of comments all over the board and just decided to just buy the crap myself and make up my own mind. Bottom line, it is hard to go wrong at this level.
Yes, I use the AQ Cinnamon between my Senn and PC. Balanced is internal to the amp/dac - connections then are made to the amp directly. If you have an external DAC, you would probably want balanced connection to amp, if amp is balanced.Appreciate the write up a lot, very detailed, thank you. Just to be clear, ur using the AQ Cinnamon cable with HDV820 to ur PC? And I’ve never had a balanced AIO, since I’d be using onboard DAC I just plug my balanced HD800s straight in, I don’t need to buy anything else to make it balanced? We have read legit the same stuff on the amp, that the dac wasn’t very good in it even tho it cost quite a bit, and that it didn’t do very good with any other headphones besides the HD800s and HD820. Glad u took the plunge and enjoy it. Did u consider the HD800s and HDV820 pairing as an all-rounder?
btw, do you already enjoy darker sound? If not, what did u think of it? I really liked the warmness of my Valhalla 2 + t.1 2nd Gen pairing
The HDV820 has both analog and digital inputs, so you can use the analog output of another DAC with the Sennheiser's analog input.When does the DAC kick in on this unit? I would hook this up to my 2 channel main set up and I really don’t need it’s internal DAC.
Maybe a dumb question, but can I bypass the DAC by hooking it up a certain way?
I want to hook up the 820 to the record out of my amp. So I can use it to hear all of the things that are connected to my amp. So, record out to the Senn analog input, right? Then no Senn DAC involved…The HDV820 has both analog and digital inputs, so you can use the analog output of another DAC with the Sennheiser's analog input.
Great advice! Thanks so much!Reading the manual should really be helpful..
You can download the manual here, but the text and photos have been upgraded since the last time I saw them, and may answer your questions:Great advice! Thanks so much!
I have not bought an 820 yet.
