PurpleAngel
Do you have (or measured) the specs of the front output of the Xonar DS, or just assume that it works well because "low impedance is easy to drive" ?
I've own the DX, DS, DX & STX and I've use several different headphones in each one.
So I would like to think I have some credibility to what works with Xonar cards.
Personally I would never buy another Xonar DS, it does not come with Dolby, but nothing really wrong with the card,
I just think the DG is a better value, you can adjust the gain for the headphones.
I think the DS can power headphones (like the HD-598) as well as any other non-amped (line out) headphone jack.
The HD-598 is only 50-Ohm, but I would never buy one to use unless I had a headphone amplifier to go with it.
The Senn HD-518 is a better value for working with un-amped (line out) headphone jacks.
But if someone is set on using the HD-598 with the Xonar DS, it will work "decently".
