Sennheiser HD 280 Pro snapped wire. Fix or replace?
Dec 28, 2020 at 3:47 PM Thread Starter Post #1 of 1
leolmx
Brazil
Hello. I'm having a lot of trouble with my HD 280 recently. The cable that connects between the two speakers keeps snapping and I have to send it for repair, but that's not even the problem. This time, the wire that comes out of one of the speakers also snapped. The technician swaped the old ones by put some Razer speakers in it, of course that the sound quality went down. What should I do now? Can I get some more wire to solder this loose end or should I buy another speaker? Where can I find this speaker? I looked all over the internet but didn't find any. This is a standard studio headphone, there must be a spare speaker that fits well. Thanks in advance.
These are the speakers with their snapped wires
*These are the speakers, the right one has the two wires snapped, the "upper" wire is the one I'm most afraid of, it didn't snap on the solder, but rather inside the casket, making it a lot more difficult to join.
