Yep, I believe they do. The cables on the headphones you mentioned aren't identical, though. (But yes, all three's cables will fit all three headphones.)
There is a picture of the difference. I bought the HD650 cable to replace the HD600 (to re-use the plugs for a DIY cable). It think the HD650 is of a bit better quality. You can also see it is twice as thick as the HD600's. The difference in sound was noticable.
