MaN227
- Jan 4, 2007
Good Day,
I'm wondering if you'd be so kind as to reply to some questions I have. I am just getting into this hifi headphone world. I want to hear your thoughts good, bad or otherwise.
here we go, I'll start with what I have.
Senn HD-650's
and have a cardas audio cable coming in the mail atm.
I have a headroom coda amp le ( It just don't seem to cut the mustard) therefore my endeavor for better stuff.
The more I look around and research the more overwhelmed I get with the seemingly endless list of choices. It appears some posters will only say that the products that they own are the best, as it helps them justify to themselves their own choices. That is fine by me. With that said, convince me then
I am wondering what amp I should get to work well with the 650's and cardas cable. I can tell you now I am no fan of brite highs, and descriptions I have read from many, of the HEED canamp it just seems to hit the sweet spot as to what I am looking for in an amp. just not sure if its the best choice or will be a very nice match for my existing gear.
so a few amps that have caught my eye are
HEED canamp
Gilmore Lite
Eddie Current ECSS
Rockhopper M3
MF x-can v3
RSA hornet M
XIN super-macro IV
DarkVoice 332
WooAudio 3
I want something that'll drive the 650's to their full potential and not be maxed out itself, but having a bit of . ... um .. headroom. Also I'd like the lowest amount of "noise" from the amp that I can get. Output wise , no harsh/brite highs and solid , deep, substantial bass and neutral to warm mids.
musical taste is an easy one, I listen to any and everything EXCEPT opera
With that said I simply like to enjoy music from the top to the bottom of the freq. range, and am in NO way interested in super revealing analytical sound. As that always seems as an overall sound to be brite , forward and harsh on the top end. Natural is what I want and having played drums for several years I know just what they sound like and want honest reproduction of the recordings not colored.
It's for a home setup. not so concerned with portable, thats another ball of wax
. As far as home setups go I see some that use a DAC , can you share your thoughts on the need of using one and any that you think would be a good match for the rest of the components? perhaps:
LiTe DAC-AH
HeadRoom MicroDAC
Fubar II USB DAC
Entech NC 205.2 DAC
HiFi Digital Audio - Super Pro
I spend a fair amount of time at the PC if that means anything.
I want to thank you now in advance, and tell you I very much value and appreciate any and all feedback you can give me. I thank you for your time and consideration and look forward to ALL replies.
One thing though, if your just trying to impress everyone with your knowledge by giving 25 lines of tech jargon, please save it for another thread
Plain English will do just fine.
Please forgive my "n00bness"
Senn HD-650's
HEED canamp
Gilmore Lite
Eddie Current ECSS
Rockhopper M3
MF x-can v3
RSA hornet M
XIN super-macro IV
DarkVoice 332
WooAudio 3
LiTe DAC-AH
HeadRoom MicroDAC
Fubar II USB DAC
Entech NC 205.2 DAC
