herman925
- Sep 29, 2013
There are a few things that I need urgent help, thus this post.
I've recently acquired the Xonar U7, thinking that it would be a good enough sound card (of which I'm quite new to) for my 5.1 system (which is an old build), the Logitech z5450.
So this is what I did at the moment.
1.) I plugged in the USB cable for the Xonar U7, installed the driver, everything seems ok for now. Haven't test the sound
2.) Connect the Xonar U7 with my Logitech z5450 via SPDIF, toslink adapter
3.) Went into Bioshock Infinite to check if there's 5.1 for my game, no luck.
4.) Downloaded 3-4 Dolby Digital test video files and testes them, no luck. (Used KM Player, checked that it was AC3 but the output was still encoded back to 2.1 somehow)
So, my question is,
1.) I assumed that this way everything should be fine, where the Xonar U7 supports Dolby and that it would send out 5.1 output to the z5450. Is that a proper assumption?
2.) I checked the Xonar U7 is compatible with Dolby Digital Live, so I assume that it produces 5.1 output for gaming? (which I failed to prove --> I went to try it on Bioshock Infinite and only 2.1)
3.) What else can I do to make it work?
So, my question is,
