Originally Posted by rcgrant
Shouldn't a PIMETA have comparable battery life to a MINT, seeing as how their circuits are virtually identical?
It
could be similar, except the Mint lacks the ground channel, so add the BUF634 [in low bandwidth is (1.5mA ?) ] and *whichever* GND opamp you chose too... usually that's about 8mA more at a minimum.
8mA+ is a pretty high percentage of the total (all other things being equal), or to look at it another way, Mint has 2 channels and Pimeta 3, with each channel having similar potential current draw so Pimeta uses almost 50% more.
HOwever, some of us (ok, maybe just me) see the Mint as a lower-cost option than the Pimeta, and might use lower-cost (& likely lower-current) opamps. Pimeta can use a browndog for a pair of single-channel opamps on L & R channels- even more current. I suppose it's technically possible on a Mint too, but if you start getting elaborate with one then suddenly you need a bigger chassis and it's size advantage isn't there anymore.
A Pimeta builder might be inclined to use higher frequency opamps, more current. Sure, nobody HAS to build it like that, but many of 'em are easily > $100 when finished so one might be aiming for least compromises possible in that price-range because it's about as big as it gets before it can't be considered portable anymore (sorry PPA fans, I don't consider PPA portable any moreso than I could pick up my home stereo receiver and carry that somewhere too, ignoring the power source). That is, if they don't need it to run all day.
The opamp & buffer spec sheets will list current consumption. You can estimate this with good enough accuracy to plan the design providing you keep the LED current minimized too.
