theseus
- Mar 31, 2013
Hi there!
As I own the on top mentioned in-ear phones which are to be driven with a FiiO M11 I need a balanced cable (4-pin 2,5 mm plug) for them cause the 3,5mm output is to weak in my opinion. The balanced output is much more powerful.
I asked at Fischer‘s for a cable but they do not produce or sell these. They recommended one made by FiiO (RC-UE 2B) but this doesn‘t work because the 2 pins are some 0,02/03 mm too thin and about 1 mm too short. Anotherone by Linsoul (Tripowin Zonie 16) sounded awful although the pins fit. The other prob was that + and - poles were swapped so the cable bow over the ears looked forward
Does anybody here know which balanced cable with an 4pin 2,5mm Plug and 2pin earphone plugs would fit and sound perfectly? I love these earphones but I also love the loud balanced output of my FiiO M11, which even sounds better than the FiiO AM5 of my FiiO Q5 headphone amp, in my opinion.
I appreciate every advice from you. Thanks in advance and forgive my clumsy english.
Cheers
Derek
Cheers
Derek
