Observing the isolation se110 must be better but what about the sound quality? Which sennheiser product can you match with se110 by considering the sound quality? Thnx for replies!
Se 110 or CX400-CX400 II according to sound quality?
- Thread starter ok1907
mp3
- Sep 20, 2008
Depends what you want and what you mean with SQ.
Low end Shure = no bass
Senn = plenty of bass
I mean the clarity of the sound. I don't want much bass but also no bass is no good. Are there earphones that offer some bass and clear sound that I can distinguish instruments easily?
- Oct 31, 2008
the se110 would be better for that, and they do have bass just not truck loads like most low end earphones do and the cx400 would.
ok thnx. So you are saying that I wont regret buying se110 instead of cx400 II for their mid-trebles?
- Oct 31, 2008
im saying if you want great isolation and that signature shure sound, ie mids focused then the se110 are not bad (depending on the price you get them for)
i gave 3 sets of them away at xmas and the recipients claim to think they they are great, my father has gone on about the clarity from them a couple of times.
if i was picking between them for myself id pick the se110 everytime
(btw what country are you in and what would budget be)
I am in Turkey and se110 cost two times cx400 but I will buy them from a web site and the difference is almost $15 there. se110: $70 and cx400 II: $55
- Oct 31, 2008
id still say the se110 over the cx400
Thnx for helping me out
