Xcalibur255
- Feb 4, 2008
I wonder if mine got more post-installation burn-in which accelerated things a bit for me.
I would imagine I am just more neurotic than you are.
And I do hope there is a cure, so someday they won't trigger me into writing these novella's.
There are many who HAVE and continue to hear changes and improvements thru time, myself included.
And by the rules of Aristotelian logic (which is the very foundation and basis of the scientific method, ie empirical method) all it takes is one example to invalidate such an assertion as being universally true.
So here's a puzzle regarding this hypothesis: how can a designer possibly design such a system if its ultimate properties are not settled until the system has been operating in the wild for a while? Calculations from nominal component properties, or measurement from short-term lab assemblies, would not carry to the long-term-in-the-wild setting. In other words, think of a design as represented by a point in very high-dimensional space, and a particular performance measurement (eg. SNR) as a function from that high-dimensional space to real numbers for which you only have a few evaluated points (those for your lab measurements). According to your hypothesis, the point representing the system will drift from its design position to somewhere else. How can the designer extrapolate from the few design/lab values they have to the value of the measurement wherever the system drifts to? There's something here that I can't figure out, even though I have some sympathy for your hypothesis.For me, after much consideration and examination, it is a matter of all of the individual components themselves getting used to being what they have been created to be, and are now operating as.
Say there Aurion.@johnjen , many years ago I worked for a solid state power supply company, and was involved with product development and testing. MTBF studies were performed with thermocouples strategically placed within the chassis. In addition, after each test the chassis was rotated through various loads, and horizontal and vertical planes. As I recall, no test procedure lasted more than a day or two for the power supply to reach thermal stability, as measured with a suitably sensitive voltmeter.
I would imagine that a few thermocouples placed within any Schiit dac would reveal when thermal stability is achieved. With a well refined ear one might determine if the point of thermal stability occurred simultaneously with end point fidelity. Just a thought for someone inclined to experiment.......
Say there US Blues.Aristotle, Aristotle was a bugger for the bottle...
Sorry, couldn't resist quoting Monty Python. In all seriousness, this is a deeply thought out post that brings to mind some new and interesting ideas regarding the real world functionality, and attendant changes in SQ, in new or "cold" gear. Thank you for sharing this.
So why would that drift always sound better at the end, unless it's user habituation rather than convergence to an operational target that as I argued would be very hard to design for? I can understand that some components might take some time to converge to their design specs. For example, new vacuum tubes. But I'm rather skeptical that a complex design will magically drift into a performance optimum just from mutual nudges between components drifting out of spec.No puzzle at all. There is no meaningful (i.e. audible by naked ear) change from design stage on paper to fully operation in the wild. However, that stated, ones "mind" (thoughts, etc.), hearing capability, beliefs, and so on are rather dynamic and can change from moment to moment. Combine that with other real-life changes (temperature, magnetism, etc.) and can one really ever be able or expected to pin point the true reason for any perceived audio change with their yggdrasil?
