Schiit Mjolnir 3 - Impressions Thread
Dec 4, 2023 at 5:21 AM Post #706 of 3,903
Dec 4, 2023 at 6:49 PM Post #707 of 3,903
Got mine today, the sound is definitely better than the Lake People G111 MK2 that I have been using for the last several months. More details, depth, sparkles, blackground, and not harsh at all. One of the best parts is more rhythm and stronger hitting bass. Bass in songs that move up and down at the various frequencies are more well defined and give songs better musicality and structure. The MJ3 is like a velvet hammer, you just feel more, there is no mistaking that it is a very good amp.
However, it did warm up my little 10X10 listening room a fair amount, I like that room cold and not a fan of the warming effect. But, I knew that going in, it is not a deal breaker. Finally, it took my LCD-2C's to another level, turning them from a bit dark to having more treble bits. I hope to get something like Dan Clark E3 to finish out this new setup, and that will be it for me for a while.
Dec 5, 2023 at 12:02 AM Post #715 of 3,903
Dec 5, 2023 at 12:07 AM Post #716 of 3,903
you wrote: "Mode, up for push-pull Class A, down for SE Class A. (considered to be the purest form of Class A). Push-pull gives you more power though. You get to choose what you like with what headphones you use."
So, the MJ3 is a balanced amplifier, but it sounds better on an unbalanced headphone output? I understand correctly?
SE Class A does not refer to the use of the unbalanced headphone output (or input for that matter). From the manual:
“Final note: "single-ended" in the context of Class A does not refer to the balanced or SE inputs. You can have a balanced differential gain stage that runs a single-ended Class A output stage. Yes, we know, engineering sucks and is sometimes confusing.”
Dec 5, 2023 at 6:10 AM Post #718 of 3,903
Did anyone from EU get a device already?
I am still waiting for any notification ..
Also didn't get any notification till now, only the one that said it will take till end of November
Dec 5, 2023 at 9:34 AM Post #719 of 3,903
