https://a.co/d/7to9oM2 For those interested in a fan solution there’s also this option. Based on the measurements it would sit perfectly above the heat sinks
Schiit Mjolnir 3 - Impressions Thread
- Thread starter XERO1
artur9
- Apr 25, 2015
I have one of those on another component. Works very well if it can draw enough air. Mine is in a closed cabinet hence the qualifier.This little unit sits right on top of my MJ3 and works great, pulls the heat up and exhausts out the back. If you are looking for something a bit more AV oriented in looks.
AC infinity Aircom S6 it's 12" wide and sits right on top of the heat fins.
I would like to be able to set the lower temperature a little lower. It is 84 and I think 80 would be better.
adydula
- Dec 14, 2010
Link doesn't work here?https://a.co/d/7to9oM2 For those interested in a fan solution there’s also this option. Based on the measurements it would sit perfectly above the heat sinks
I never really understood the paranoia about class-A amps getting hot. It is their nature. They get hot.
I can understand this obsessed usage of fans in case your space is limited for the amp and cannot ensure enough airflow or distance from surfaces from all directions (top, bottom, sides), but in fact all you need is a stand to lift the amp a little and just let it breathe. This way I can put my hands on the heat sinks even after hours.
Yea i completely agree, i don’t own a fan for my MJ3 although i do elevate it as it will heat up the surface of my desk if i don’t, but yea I let mines cook away. I get all sorts of pops and cracks with my unit but these are just from components increasing and decreasing in size due to temperature and i remember Jason saying these are things that the MJ3 just does. Also, these are the reasons he says the MJ3 isn’t for everyone. However, the way it sounds is undeniably beautiful.I never really understood the paranoia about class-A amps getting hot. It is their nature. They get hot.
adydula
- Dec 14, 2010
Ha!
Obsession over heat. well sir heat is the enemy of all things electronic for sure.
Class A runs hot, the duty cycle is 100%.
That said most Class A amps are well heatsinked. Some more than others...
One of the big added cost in a Class A amp well heat sinked amp are those often HUGE heatsinks.
That said a MJ3 should run fine with the heatsinks they have...but it does get hot.
Using a fan IMO is a great idea not an obsession.
Which ever way you go be happy..but the cooler the better for me.
Alex
Alex
If possible to help it run cooler, that is a good thing. If not possible or desired, the amp will still work, just a lot hotter, either way it sounds really good.
The benefit is much less probability of things going wrong with the amp run cooler. Admittedly my fan solution does look ghetto, but it works darn good.
The other fan solutions look a lot better, cost a lot more, fit in tight racks a lot better, and I need to be saving for my Caldera. Working man's blues right? All good.
adydula
- Dec 14, 2010
Ha! Sometimes "ghetto" is good!
Alex
Alex
Slackaveli
It's always been a slight misconception about the temps getting hot then sounding better. They need only be stabilized for the improvements to come into play.
So once you have reached a temperature that can be maintained you are good. That could be 60c or 80c depending on cooling and once it reaches a temp that is consistent you are good to go.
Now imo the lower temp is always better bc everything degrades more at higher temps.
I think, my MJ3 has properly burned in now.
I am glad to report that the treble definitely feels a lot smoother than at the beginning. MJ3 is certainly a unique amp with a special flavour amongst solid states. That kicking bass is super entertaining and mids are surprisingly sweet with good timbre. I do not find the treble bothering at all anymore, but it is certainly that area on the MJ3 which could use a little more refinement. All-in-all it is a very fun and entertaining listen, especially with some EDM.
centuriones
Finally my Mjolnir 3 is delivered tomorrow.
I can't wait to listen to it with my Elite headphones and Pontus II dac.
got my MJ3 back a week ago but was on vacation. Finally got to set it up a few nights ago and run it. From the repair paper, looks like they changed a few caps, some resistors, and diodes for stability. Visually on both channels they changed out both front most caps to the black ones now.
Interesting, wish they mentioned the swaps they did when mine was in the repair for the gain switch, but the paperwork just mentioned the gain switch. Visually mine has one black and one blue capacitor on each side now.got my MJ3 back a week ago but was on vacation. Finally got to set it up a few nights ago and run it. From the repair paper, looks like they changed a few caps, some resistors, and diodes for stability. Visually on both channels they changed out both front most caps to the black ones now.
artur9
- Apr 25, 2015
Remember, it takes a while, from new, to reach peak.Finally my Mjolnir 3 is delivered tomorrow.
Is the consensus that "warm up" for a new MJ3 takes hours or days?
Consensus for a "broken in" MJ3 "warm up" takes an hour?
