watchnerd
- Jul 12, 2008
They offered a DSD decoder, and it failed. They killed off the product after its initial production run sold off, which took years.
Yes, I know.
Well, the scratchy noise is there with the slightest turn on the knob on my Fulla 2, with or without sound. I guess its a faulty unit. I have to admit the volume on mine looks aligned. I love the sound of the Fulla 2 I am very disappointed I got a bad Fulla.
Did you ever resolve the scratchy pot issue with them?
Hi guys,
Yes. the left driver had the static noise more pronounced, especially on lower volume. I filled out the online RA form, told them I didn't want a refund, but a good working unit. Just one hour later they emailed me a Fedex Label to return it. I re-packed it and dropped at a FedEx location then emailed them as soon as FedEx showed it as received and they immediately mailed me the replacement. I received the replacement today via USPS Priority.
The new unit has the Volume Knob centered, thats what it looks to me. Usb ports tight, its ok. The volume pot is quiet with music or without it. The sound is perfect. Everything works good, I hope it stays that way and I am very thankful to Schiit for making this right and it didn't cost me a penny more.
Thanks to the guys that helped me here otherwise I would had just returned it.
Hi guys,
Glad to hear it worked out. Mine is physically ok - knob is straight-ish, ports plug fine - but sonically I do hear a sort of woosh-like sound out of both channels if I turn the knob quickly without any music. The sound isn’t the typical scratchy sound from an bad pot, it’s a more uniform sound that doesn’t hinder performance - but something that doesn’t occur with other amps that I own...
What does "2Hz-200KHz, -3dB" in the specs mean? Bass cut?
Mine is totally silent always.
Hi guys,
Returned it immediately for refund due to the scratchy off center volume pot. They sent me a message that unit tested okay but sent full refund. At the time of the return I could not find anyone with this issue. I thought it was just me or that they were all this way. Now I see it was very common. On my unit if I put pressure in a certain place when turning volume up no scratchiness would occur
