Countless others have done such tests. (And most have failed.) I'd recommend posting your results in this thread and clarifying the bit rate of the MP3 and whether you converted it yourself.
https://www.head-fi.org/threads/set...le-guide-to-ripping-tagging-transcoding.65587
Countless people are not me
. I am a trained listener and managed the signal processing group (among many others) at Microsoft. You can read more about me here:
https://www.audiosciencereview.com/forum/index.php?threads/a-bit-about-your-host.1906/
Thanks for the note on bit rate. I assumed it was part of file name but it is not. That test was at 320 kbps which is hardest level for MP3. Of course I did the encoding.
Here is another 320 kbps vs CD from a test on AVS Forum:
http://www.avsforum.com/forum/91-au...-high-resolution-audio-test-ready-set-go.html
foo_abx 1.3.4 report
foobar2000 v1.3.2
2014/07/31 15:18:41
File A: C:\Users\Amir\Music\AIX AVS Test files\On_The_Street_Where_You_Live_A2.mp3
File B: C:\Users\Amir\Music\AIX AVS Test files\On_The_Street_Where_You_Live_A2.wav
15:18:41 : Test started.
15:19:18 : 01/01 50.0%
15:19:30 : 01/02 75.0%
15:19:44 : 01/03 87.5%
15:20:35 : 02/04 68.8%
15:20:46 : 02/05 81.3%
15:21:39 : 03/06 65.6%
15:21:47 : 04/07 50.0%
15:21:54 : 04/08 63.7%
15:22:06 : 05/09 50.0%
15:22:19 : 06/10 37.7%
15:22:31 : 07/11 27.4%
15:22:44 : 08/12 19.4%
15:22:51 : 09/13 13.3%
15:22:58 : 10/14 9.0%
15:23:06 : 11/15 5.9%
15:23:14 : 12/16 3.8%
15:23:23 : 13/17 2.5%
15:23:33 : 14/18 1.5%
15:23:42 : 15/19 1.0%
15:23:54 : 16/20 0.6%
15:24:06 : 17/21 0.4%
15:24:15 : 18/22 0.2%
15:24:23 : 19/23 0.1%
15:24:34 : 20/24 0.1%
15:24:43 : 21/25 0.0%
15:24:52 : 22/26 0.0%
15:24:57 : Test finished.
Total: 22/26 (0.0%)
From same tests, this time testing high-resolution audio against resample to 44.1/16:
foobar2000 v1.3.2
2014/07/11 06:18:47
File A: C:\Users\Amir\Music\AIX AVS Test files\Mosaic_A2.wav
File B: C:\Users\Amir\Music\AIX AVS Test files\Mosaic_B2.wav
06:18:47 : Test started.
06:19:38 : 00/01 100.0%
06:20:15 : 00/02 100.0%
06:20:47 : 01/03 87.5%
06:21:01 : 01/04 93.8%
06:21:20 : 02/05 81.3%
06:21:32 : 03/06 65.6%
06:21:48 : 04/07 50.0%
06:22:01 : 04/08 63.7%
06:22:15 : 05/09 50.0%
06:22:24 : 05/10 62.3%
06:23:15 : 06/11 50.0%
06:23:27 : 07/12 38.7%
06:23:36 : 08/13 29.1%
06:23:49 : 09/14 21.2%
06:24:02 : 10/15 15.1%
06:24:10 : 11/16 10.5%
06:24:20 : 12/17 7.2%
06:24:27 : 13/18 4.8%
06:24:35 : 14/19 3.2%
06:24:40 : 15/20 2.1%
06:24:46 : 16/21 1.3%
06:24:56 : 17/22 0.8%
06:25:04 : 18/23 0.5%
06:25:13 : 19/24 0.3%
06:25:25 : 20/25 0.2%
06:25:32 : 21/26 0.1%
06:25:38 : 22/27 0.1%
06:25:45 : 23/28 0.0%
06:25:51 : 24/29 0.0%
06:25:58 : 25/30 0.0%
06:26:24 : Test finished.
Total: 25/30 (0.0%)
So again, high confidence results. I think the files are still there if you want to try to take the test yourself.
Here is another test that Archimago put up, again on high-res vs not:
foobar2000 v1.3.2
2014/08/02 13:52:46
File A: C:\Users\Amir\Music\Archimago\24-bit Audio Test (Hi-Res 24-96, FLAC, 2014)\01 - Sample A - Bozza - La Voie Triomphale.flac
File B: C:\Users\Amir\Music\Archimago\24-bit Audio Test (Hi-Res 24-96, FLAC, 2014)\02 - Sample B - Bozza - La Voie Triomphale.flac
13:52:46 : Test started.
13:54:02 : 01/01 50.0%
13:54:11 : 01/02 75.0%
13:54:57 : 02/03 50.0%
13:55:08 : 03/04 31.3%
13:55:15 : 04/05 18.8%
13:55:24 : 05/06 10.9%
13:55:32 : 06/07 6.3%
13:55:38 : 07/08 3.5%
13:55:48 : 08/09 2.0%
13:56:02 : 09/10 1.1%
13:56:08 : 10/11 0.6%
13:56:28 : 11/12 0.3%
13:56:37 : 12/13 0.2%
13:56:49 : 13/14 0.1%
13:56:58 : 14/15 0.0%
13:57:05 : Test finished.
Total: 14/15 (0.0%)
To be clear though, you are right that people routinely and almost completely fail to pass such tests. But with skill and quick switching (which was topic of discussion) some of them can be passed. In some instances here what showed the difference was just a second or two of music or even just single note! No way can you remember and focus on such detail when listening to minutes of music.
