tkddans
- Jul 18, 2016
Did that too :/One thing to look at is to go to System Preferences/Sound and select the Bifrost. In the bottom right make sure Mute is not checked.
Tried all input settings using the button on the front. Double checked wires connecting from inputs to outputs. Not that I changed anything since it was working anyway. One day working….next day not.Make sure the BF2's input is set to where you think it should be.
I’ll try adjusting that in the system when I get home. Thanks for the advice!Do the BF2's relays click at all if you change the bit rate and/or depth? That was my clue my BF wasn't set to the correct input. If you're sure your input is correct and you can't hear any relays, the BF either isn't responding or your source isn't transmitting. Good luck!
I honestly would pick BF2. The main reason being you can hook up two amps simultaneously with the BF2 (XLR + RCA) while the Ares 2 only supports one at a time (XLR or RCA). Also, if you are gonna use the USB input, the BF2 because the unison is a better usb implementation. I use to own both and now I have the BF2. But i eventually bought a Denafrips Pontus 2. I dont think you can go wrong with the BF2.I'm ready to upgrade from my entry level Schiit DACs. My Modi multibit has been a favorite for a long time but I also like the Modius and Modi 3. The Bifrost 2 is as high as I can go in price, I'm retired, but now the Denafrips Ares II has piqued my interest. If you were in my shoes what do you think you'd do? I use an Asgard 3 amp and Focal Clear Pro headphones. No streaming, CD playback on an Audiolab transport.
Coax only. I'm leaning towards the Bifrost 2 because I own and have owned Schiit gear and have always been impressed with their equipment. Thanks for your input.I honestly would pick BF2. The main reason being you can hook up two amps simultaneously with the BF2 (XLR + RCA) while the Ares 2 only supports one at a time (XLR or RCA). Also, if you are gonna use the USB input, the BF2 because the unison is a better usb implementation. I use to own both and now I have the BF2. But i eventually bought a Denafrips Pontus 2. I dont think you can go wrong with the BF2.
This seems to be a somewhat common occurrence on Macs though I have no idea why it happens (I'm a victim of this, too). It's frustrating and the fix isn't exactly intuitive but I'm glad to hear you've sorted it out and can start to enjoy your BF2.So silly. I went into Audio Midi Setup on the Mac...and the freakin mute box was checked. How does that even happen?
And I just ordered a Topping DAC and it's already shipped! So silly.
I guess I'll just have to do a video comparing DAC's now! lol That could be interesting I suppose...
It's good we can admit to being an idiot at times. In my case, it's more like 99.9% of the time. Prime example - I thought my brand new BF2 was DOA right out of the box because I couldn't hear anything whatsoever. I swore I had the input source selected correctly, but after Schiit's customer service told me to RTFM...again, I did. Well, um...why is this LED on and not that one? After selecting the correct input, lo and behold wondrous sound! Hello, my name is Gumby. I'm an idiot.So silly. I went into Audio Midi Setup on the Mac...and the freakin mute box was checked. How does that even happen?
I have never experienced this muself as far as I can remember (which, admittedly, may not be long) but I’ll definitely try to remember this. It’ll sure save me some frustration and nervosa when it happensThis seems to be a somewhat common occurrence on Macs though I have no idea why it happens (I'm a victim of this, too). It's frustrating and the fix isn't exactly intuitive but I'm glad to hear you've sorted it out and can start to enjoy your BF2.
No XLR, just straight RCA to my Asgard 3. Would you still go Bifrost 2 over the Ares II just based on sound quality. Since I love what the Modi multibit does I think that the Bifrost 2 would be the next step.I honestly would pick BF2. The main reason being you can hook up two amps simultaneously with the BF2 (XLR + RCA) while the Ares 2 only supports one at a time (XLR or RCA). Also, if you are gonna use the USB input, the BF2 because the unison is a better usb implementation. I use to own both and now I have the BF2. But i eventually bought a Denafrips Pontus 2. I dont think you can go wrong with the BF2.
If you want to know about the sound, i think BF2 is dynamic and punchy while the Ares 2 is warm and gooey with a very laid back presentation. Since you have a SS amp, i think bf2 would suit you better as well. If you ever consider a tube amp, then the Ares 2 would sound pair better.No XLR, just straight RCA to my Asgard 3. Would you still go Bifrost 2 over the Ares II just based on sound quality. Since I love what the Modi multibit does I think that the Bifrost 2 would be the next step.
