Schiit Archive - Legacy Product Manuals and Specifications
Jan 31, 2020 at 3:01 PM Thread Starter Post #1 of 13
liquidsmote
Thread dedicated to posting manuals and specifications for Schiit legacy products!
Current dedicated archive URL: https://el8442.wixsite.com/schiitarchive
UPDATE!
We're working on a dedicated archive of the Schiit product stack. When possible, the archive will have drivers, manuals, and specifications. Will also be tracking exactly what's available for which product, and exactly what's needed for the archive. This should help keep the thread as clean as possible too!
UPDATE!
New categories created specifically for drivers and manuals. New categories also created for each year 2010 - 2019. Archives may now be sorted by product category, year, or specifically for drivers/manuals. Posts will be starting in earnest ~ 2/14, so don't be alarmed by the initial trickle!
UPDATE!
Now featuring primary product posts along with dated archive posts! Thank you to @JamminVMI for putting together the complete packages! Primary product posts are featured on the front page of the archive, and are also searchable, and also may be located by product category / featured category.
UPDATE!
Specifications, manuals, and drivers are available for the entire product stack for the following years: 2010, 2011, 2012, 2013
Jan 31, 2020 at 3:06 PM Post #2 of 13
Schiit Saga (Original - OG)
DATE INFO SOURCED: 12/08/2017
Frequency Response: 20Hz-20Khz, -0.2db, 3Hz-200KHz, -3dB (active stage)
THD: <0.002%, 20Hz-20KHz, at 2V RMS (active stage)
IMD: <0.002%, CCIR (active stage)
SNR: >108db, A-weighted, referenced to 1V RMS
Crosstalk: >-75dB, 20Hz-20KHz
Output Impedance: 180 ohms
Input Impedance: 10K ohms
Gain: Approximately 1 (0dB) through either passive or active stage
Maximum Output: >10V RMS (active stage)
Inputs: 5 RCA pairs, selectable via front switch or remote
Outputs: 2 RCA pairs, selectable via front switch or remote
Buffer Stage: Hybrid push-pull 6H8C-BJT buffer stage with equalized transconductance
Volume Control: relay-switched stepped attenuator with discrete thin-film resistors , 64 1dB steps
Power Supply: One 24VA transformer with regulated +/-100V rails, plus 6.3VAC heaters and 5VDC for microprocessor
Power Consumption: 25W typical
Size: 9” x 6” x 2”
Weight: 6 lbs
Manual: http://web.archive.org/web/20171208...iit.com/public/upload/PDF/saga_manual_1_2.pdf
Jan 31, 2020 at 9:36 PM Post #3 of 13
Jan 31, 2020 at 9:54 PM Post #4 of 13
Here are some more pdfs
wyrd
USB Ports: 1 in (Type B) and 1 out (Type A)
USB Mode: USB 2.0 (480Mbps), backwards-compatible to USB 1.1
USB Packet Repeater: Controlled via 20ppm crystal oscillator
USB Power Current Capability: Over 500mA (full USB 2.0 spec)
Power Supply Type: linear, with precision low-noise (2.5uV) voltage regulators
AC Power: 9VA 6VAC wall-wart
Power Consumption: 6W maximum, <1W typical (depends on power draw of USB device)
Size: 5 x 3.5 x 1.25”
Weight: 1 lb
bifrost
Bifrost
D/A Conversion IC: AKM Verita® AK4490
Analog Stage: Fully discrete, DC coupled
Frequency Response: 20Hz-20KHz, +/-0.1dB, 2Hz-100KHz, -1dB
Maximum Output: 2.0V RMS
THD: <0.003%, 20Hz-20KHz, at max output
IMD: <0.004%, CCIR
S/N: >108dB, referenced to 2V RMS
Bifrost Multibit
D/A Conversion IC: Analog Devices AD5547CRUZ
Digital Filter: proprietary Schiit bitperfect closed-form digital filter implemented on Analog Devices SHARC DSP processor
Analog Stage: precision I/V converter and output buffer based on AD8512
Frequency Response: 20Hz-20KHz, +/-0.1dB, 2Hz-150KHz, -1dB
THD: <0.005%, 20Hz-20KHz, at max output
IMD: <0.008%, CCIR
S/N: >109dB, referenced to 2V RMS
All Bifrosts
Inputs: Coaxial SPDIF, Optical SPDIF, USB
Input Capability: up to 24/192 for all inputs, including 24/176.4
Input Receiver, SPDIF: AK4113, USB: C-Media CM6631A with electromagnetic and electrostatic isolation
Output: RCA (single-ended)
Output Impedance: 75 ohms
Power supply: 5 stages of regulation, including separate supplies for critical digital and analog sections.
Upgradability: Separate, modular USB Input Card and DAC/Analog Card are snap-in replaceable.
Power Consumption: 12W
Size: 9 x 6.75 x 2.25”
Weight: 5 lbs
asgard 2
Frequency Response: 20Hz-20Khz, -0.1db, 2Hz-400KHz, -3dB
Maximum Power, 32 ohms: 1.0W RMS per channel
Maximum Power, 50 ohms: 1.0W RMS per channel
Maximum Power, 300 ohms: 380mW RMS per channel
Maximum Power, 600 ohms: 190mW RMS per channel
THD: Less than 0.008%, 20Hz-20KHz, at 1V RMS, high gain mode (worst case)
IMD: Less than 0.010%, CCIF at 1V RMS, high gain mode (worst case)
SNR: More than 102db, unweighted, referenced to 1V RMS, in low gain mode
Crosstalk: Less than -72dB, 20Hz-20KHz
Output Impedance: Less than 2 ohms
Input Impedance: 100K ohms
Gain: High = 6 (15.6db) or Low = 1.5 (3.5db), via rear switch
Topology: Fully discrete, single-ended Class A with single voltage gain stage, no overall feedback in high gain mode, 12dB feedback in low gain mode
Protection: Standard muting relay for delayed turn-on and fast turn-off
Power Supply: Internal power transformer with 4 separate power supply rails and over 20,000uf of filter capacitance
Power Consumption: 30W
Size: 9 x 6 x 2.25”
Weight: 5 lbs
jil
Inputs: RCA stereo (single-ended)
Input Range: 400uV-3.5V RMS
Sample Rates and Bit Depths: 48kHz, 96kHz, 192kHz, 24 bits
Frequency Response: 20Hz-20KHz, +/-0.1dB, 2-100kHz, +/- 3dB
IMD: <0.003%, CCIR
S/N: >110dB, unweighted, referenced to 2V RMS
Crosstalk: -82dB, 20-20kHz
Output: USB 2.0 (compatible with USB 3.0 and 3.1 ports)
ADC: AKM AK5385
USB Output: C-Media CM6631A
Power Supply: Linear, 16VAC wall-wart and low-noise local regulation
Weight: 1 lb
Jan 31, 2020 at 10:40 PM Post #5 of 13
Jan 31, 2020 at 10:41 PM Post #6 of 13
Jan 31, 2020 at 11:53 PM Post #7 of 13
Feb 2, 2020 at 2:15 PM Post #8 of 13
Thread dedicated to posting manuals and specifications for Schiit legacy products. Please contribute by making a post per product with specifications and PDF manuals!
Here goes. One zipfile per post, including product photos, pdf manual, pdf of specs, descriptions, etc. from the 'wayback machine. JM
First up: Bifrost OG 4490/Multibit.
Feb 2, 2020 at 2:19 PM Post #9 of 13
LOKI MINI (Should have said in the previous post that the Specs pdf includes the description, specs and FAQ tabs from the product page.) And I forgot my academic hat and failed miserably to record the date from the WayBack Machine's site grab - so no API-formatted footnotes for you - yet...
Feb 2, 2020 at 2:21 PM Post #10 of 13
Magni 3
Feb 2, 2020 at 2:22 PM Post #11 of 13
Saga OG
Feb 3, 2020 at 2:53 PM Post #12 of 13
This thread should not be necessary. But thank you for doing it :(
Feb 3, 2020 at 5:59 PM Post #13 of 13
This thread should not be necessary. But thank you for doing it :frowning2:
No worries! This thread will be a great secondary resource, but we're working on a standalone archive for the entire Schiit product stack! Working on this methodically so we'll know exactly what we have archived, and exactly what's needed!
