JohannLiebert
- Jan 18, 2012
No, output impedance measurement -.- Considering Multidriver IEM's are the most popular portable solution for "audiophiles".
Got the Senn IE800 today, makes interesting listening on the Note...
Each volume level introduces a certain level of distortion / static - oddly 13 is the noisiest, and 14 / 15 cut the noise right down - not really sure what is going on there!
In the Note 3's defence, the IE800s are handled very well when using Neutron - Is incredible what this little combo can do...
Does anybody have some external hard drives they could test with the Note 3?
The Note 3 has a USB 3.0 connector. Even though no USB 3.0 OTG, or Superspeed OTG, cables exist yet to my knowledge, it would still be very interesting to see what output current is available when using a USB 2.0 OTG cable.
It is conceivable that the Note 3 would allow for up to 500mA output power when using a USB 2.0 OTG cable. If that were the case, it would be able to power the vast majority of DACs and portable external hard drives.
If the Note 3 is like other phones, it may have seriously gimped output power or 100mA or so. If that were the case, then it will be relatively limited without the use of a USB OTG Y-cable and additional power source.
Tested my N9005 with my 2TB external hard drive (exFAT formatted) using a USB 2.0 OTG (not Y). It's working perfect.
Hi Duncan, could you please elaborate a little as well as give us an update on your ie800 + GN3 experience? Any word on the distortion/static? Is this only with stock player?
I am a little disappointed in my GN3 performance; my gn2 with Wolfson DAC had a much wider soundstage and better imaging with Neutron Player and HiRes FLAC. This is with ATH11-LTD, SEN PMX680I and PXC 310 BT (both wired and AptX BT). My whole point in moving to GN2 was to drop DAC and Amp bundling, as I had used previously with iPhone4s, and the GN2 was working so well for me that I upgraded to the GN3 without anticipating a degradation in sound stage, though the GN3 does have higher output and the instrumentation is very accurate.
So, my real question is, do you find the IE800 +GN3 combo sufficient? Or do you think amping/DAC are necessary?
I read through the IE800 thread (all 105 pages, lol) and am intrigued, so your input on the above topic would be greatly appreciated.
Thanks
sold my NOTe 3 because I was unsatisfied with the loudness through the headphones. Any one faced the same issue, i was afraid to ROOT it to try the different volume boosting apps
The Android hiss is killing me on the GN3. You guys have any solutions? In on the ATT version. I have tried it with both IE80 and Weston 3.
Sent from my SAMSUNG-SM-N900A using Tapatalk
