reddragon
- Dec 23, 2011
I consider the GR07 an upgrade from the HF5, yes. It extends better on both ends, has better soundstage and imaging, and being a dynamic it has more natural-sounding decay.
that sounds good.
GR07 will have that sub bass you seek. It is present and can be pretty strong when called for but usually polite and non-intrusive.
that sounds good.
Hmm, some people find the GR-07 harsh too, so I don't know if they will suit you... but the soundstage and imaging are certainly better than the HF5.
then why do you think hf5 is better than gr07?
