Many say that RSA amps are dark. Does this mean that it's on the warm side or that it's quiet, silent?
RSA owners say it's dark
- Thread starter sling5s
Drag0n
- Jun 11, 2004
Its warm , meaning bassy.
Cold is a detailed sound with the bass sorta rolled off, and may be thin.
Warm is fuller and the bass is the foundation of it, highs may be a bit either rolled off, or just not as prominant.
Dark is very warm, rolled off highs, bassy.
Hard to explain it, although i know what it is when i hear it.
Just like chocolatey, syrupy, vanilla, mellow, sweet, cottony, pillowy, musical, fast, slow, bloated, thin, thick, round, sharp, smiley faced, reverse smiley, clinical, analytical, tubey, hard, soft, solid, loose, flabby, balanced, neutral,piercing, forward, laid-back, 1st row, 3rd row, fat, deep, wide, narrow, head stage, sound stage,
metalic, boxey, attack, decay, separation, ......ETC!
Look at all these words while listening to music, and imagine the sound of each description, and read how others describe equipment that youre familiar with.
Funny how equipment can sound chocolatey
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
Bob_McBob
- Jul 24, 2005
Why exactly did you edit this thread from the original topic about Justin not sending your Pico back?
TheMarchingMule
Originally Posted by Bob_McBob /img/forum/go_quote.gif Why exactly did you edit this thread from the original topic about Justin not sending your Pico back? |
- Jun 7, 2007
I missed that change but anyway, i have both a Pico and a RSA Hornet M and the way i hear it is..........
The RSA Hornet M has more bass and more gain if needed it seems but a higher noise or maybe distortion level. The Pico sounds to me to have less bass or punchier bass not as full but then a very low noise floor and better detail. So yes the Hornet is warmer for sure but with other disadvantages, just depends how you like your music.
Bob_McBob
- Jul 24, 2005
WEEEEEEEEEEEEEEEEEEEEEEEEEEEE
peanuthead
- Nov 19, 2008
Originally Posted by Bob_McBob /img/forum/go_quote.gif WEEEEEEEEEEEEEEEEEEEEEEEEEEEE |
TheMarchingMule
LOL read the reason why he edited it.
![wink.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/wink.gif)
peanuthead
- Nov 19, 2008
Ha ha. Got it.
Originally Posted by TheMarchingMule /img/forum/go_quote.gif LOL read the reason why he edited it. ![]() |
Ha ha. Got it.
mrarroyo
- Jul 27, 2005
Both!
I find that Ray's amps have a silent background and are on the warm side. Plus Ray has one of the best customer service anywhere.
Originally Posted by sling5s /img/forum/go_quote.gif Many say that RSA amps are dark. Does this mean that it's on the warm side or that it's quiet, silent? |
Both!
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/biggrin.gif)
I would guess if RSA's are dark (warm) then it would not be a good match for the hd650 since they tend to be on the warm side too. I had the XP-7
and Sr-71's. I guess I should have gone with a more bright amp.
mrarroyo
- Jul 27, 2005
sling5s if you have an original SR71 do not sell it! It is one of the most balanced sounding amps and a joy to use w/ all kinds of headphones.
Drag0n
- Jun 11, 2004
Ray cant get parts for the SR71 anymore, so he cant make anymore, so if u like it, keep it, cuz u cant buy another one except used.
scaz
- Mar 26, 2008
Cool I was thinking I wanted to start saving up for the Raptor to go with my HD650s. I like my bass and my music a little warmer. One of these days I will have to get some brighter head phones.
olblueyez
Banned
- Jun 16, 2008
Swapping out tube on the Raptor can give you a plethora of sonic signatures, there are sooooooooo many tube rolling options.
Originally Posted by scaz /img/forum/go_quote.gif Cool I was thinking I wanted to start saving up for the Raptor to go with my HD650s. I like my bass and my music a little warmer. One of these days I will have to get some brighter head phones. |
