Mecc
- Aug 5, 2005
I also just got some new RS-1, buttonless model. My opinions are similar to the op. I ordered some flat pads because some people said that they prefer them vastly over the bowls, e.g., some guy from 6moons.
I'm also using Stello DA-100, except EF-1 as the amp. The RS-1 will be balanced eventually.
I noticed that you have to wear the earpads so that your earlobes are inside the bowl. It really puts you into the music, but it gets a bit uncomfortable (physically) after a while. The highs aren't that harsh for me, but its effect on certain recordings can be distracting. Hopefully it'll soften up with burn-in. The RS-1 are very engaging and the bass was quite a surprise for me. I'm used to hearing detail with a lean and/or cooler presentation. People said that the flat pads give the RS-1 more bass which isn't something I really wanted, but I think they tame the highs as well.
The GS1000 presents the lows, mids, and high in a similar fashion, but with a huge soundstage (mids are less engaging as a result), so I don't know why people say the GS1000 doesn't sound like a Grado. I tried the huge bowls on the RS-1, kinda weird, the sibilance (sss) was more pronounced. The sibilance on the GS1000 is more (chh, ji, and a variety of sounds). They might be the perfect headphones for me if they didn't exhibit those sounds. I tried the bowls on the GS1000 and what do you know, less sibilance, but the music sounded odd and the sound stage got zipped up.
The RS-1 sounds good with certain genres, but then they are too much for others. A bit odd perhaps, but I found some pop songs to be too engaging or overwhelming for me. Perhaps it has to do with the recording. I also noticed that pop songs sound better to me on lesser equipment compared to other genres. So, maybe this is the louder equalizer crap that's I'm hearing.
