Kurt
- May 21, 2004
The first things that are coming to my mind when reading this are the stories about Grados bad solder joints of the cables I read here on head-fi.
Originally Posted by Cerebral_Mamba Strange, my RS1s show impedences of 32.5ohm & 32.7ohm. My 10 $ Koss shows ratings of 32.0ohm and 32.1ohm. Grado really needs some serious manufacturing automation and quality control. |
Originally Posted by lini I also generally wouldn't recommend to do that - especially if you don't know what voltage the meter applies for resistance measurements - in order not to damage the drivers. |
Originally Posted by lini Hmmm, all those multimeter tests are only dc resistance (= not the same as impedance) measurements, anyway. I also generally wouldn't recommend to do that - especially if you don't know what voltage the meter applies for resistance measurements - in order not to damage the drivers. Greetings from Hannover! Manfred / lini P.S.: Lisa: Do you happen to have access on some piece of equipment with a headphone jack and a mono switch - or some kind of mono adaptor (like a stereo interconnect that's been bridged to mono) you could use? I found that very helpful for testing purposes... |
Originally Posted by Lisa There isn't any static with the headphone amp but still if the integrated would put out static it should be audible in both drivers, shouldn't it? |
Originally Posted by Lisa (...) Shouldn't there be static in both driver if it's the amp? There isn't any static with the headphone amp but still if the integrated would put out static it should be audible in both drivers, shouldn't it? (...) |
Originally Posted by lini P.S.: Btw, the surprise part has arrived in the meantime - would have been a basic digital multimeter. But from this very thread I gather you already have a basic multimeter. Thus I'm frustrated now - and thinking about a new surprise part... *sigh* |
