FreeBlues
Lots of comments on many different threads about the sound quality of Rockbox and whether it's better than the firmware your player shipped with. I thought I'd start a thread dedicated to just this issue alone.
Here's what I'm wondering - using the hardware you have now and several tunes that you know well, changing NOTHING but the firmware, does Rockbox sound better?
Here's my take: yes, all other things held constant, Rockbox delivers a much cleaner, more detailed and wider soundstage with my stuff. Bass in particular is tighter, punchier, more detailed. With Apple I get sort of an undifferentiated, bloated bass drone. With Rockbox I can follow the bass line clearly. Instruments are more clearly separated, easier to pick them out of the mix. more dimensional. Highs are more extended, some of the hash and harshness is gone. Drums have more kick. The soundstage is deeper. It's much easier to relax into the music.
I compared several songs ripped in Apple lossless and transferred onto a 5g iPod, 30gb, connected via an AudioLineOut Jenna into a Total Airhead to Westone ES2's.
I switched back and forth between Apple and Rockbox and listened to the same songs several times. I didn't use any EQ with either system (btw, I found the Hardware EQ setting on Rockbox to be just terrible) and kept volume level equal and constant.
My take, the hype about Rockbox's sound quality is for real.
