Febs
- Mar 25, 2005
Most users will use the EQ to boost, rather than cut, frequencies. This adds gain. If your files are mastered hot, the added gain will push them over the 0dB line, thus pushing them into clipping. The "pre-cut" feature allows you to lower the overall gain of the music to compensate for the gain that is being added through the equalizer. This allows you to use the EQ to shape your sound without adding distortion.
