geek42
- Mar 25, 2004
It'll really depend if the scratching is on the bottom, or if the label side is scratched through. I had to give up on a couple of my cd's with label side scratches.
Originally Posted by NPoet Honestly first thing to do before you get a scratch remover... hand soap and water... really I found that if you just soap the bottom well, wash it off and dry with a soft towel it will make the cd readable the vast majority of the time... odd, but hey... it works |
