justin2net
- Feb 7, 2007
I am very close to ordering a RSA Hornet/Tomahawk (I'll ask that question to Ray) and a Qables LOD for my ZVM. Should I buy a right-angled IC or a straight:
1. If I have the amp strapped onto the bottom of the ZVM, the cable would make a U pointing towards the in of the amp, with the right-angled plug downwards. (to the right, it hits the volume knob, upwards it won't go in because it will hit the bottom of the ZVM, and to the left, obstructing the out port to IEMs).
If I decide to have it in a mp3 portable bag: http://www.caselogic.com/mp3_travel_...?modelid=44255
a right angle would be ideal, but, as stated on the Qables website, I must specify if the connector will be to the right, left, upwards, or downwards.
Should I just stick with the straight plug?
