- Jan 30, 2011
I'm listening to balanced right now, and had an adapter made to isolate the cable in the equation. Using the DACAMP L1 as the source, the single-ended doesn't have enough power to drive the CL1, so yes, balanced is necessary in this case. For all the talk of needing to amp these headphones, the DACAMP is actually a pretty weak-sauce amp. These IEMs need some current to wake up. I just got these in, so I'll be testing for a bit longer, but if you only listened to the CL1 in single-ended off the DACAMP, you might as well have not heard them at all.
With my adaptors I tried the CL1 with the Aune M1S in both balanced and single ended, the Aune sounds good with it on both, but I haven't done any volume matched critical listening at this point. It's been basically will it play and how does it sound to this point.
LOL Micah - I ended up getting balanced working and was able to measure.
http://www.head-fi.org/products/rha-dacamp-l1/reviews/17781
Anyone who suggests that single ended cannot power the CL1 properly either has a broken L1 or is fooling themselves. Check my review. Check the measurements. Power output is practically the same. Oh and frequency doesn't change either. Did you get a defective unit?
