zazex
The plastic is weak. I've had 3 pairs crack on me.
I think the company offers a free modification to prevent that,
which has been incorporated into their more recent production headphones.
I have the new pairs with the metal clasp. That's not where they're cracking. They are cracking where you slide the cups up and down to adjust for head size. This is the second pair that cracked there. The first pair cracked at the clasp which is now metal. All in all, if they were just to replace the plastic with metal or a more robust type of plastic and include a better carrying case they'd have a very hard to beat portable.
The treble is fine with most of my music, but there are tracks that are simply painful to listen to if I don't tame the highs a bit.
I've replaced the stock pads multiple times, are you trying to put a new pair of on1 pads or are they from another vendor?
Did you remove the rings or just pulled the pads off?... There's a ring that twists and locks into place, it's easier to put the earpad on the ring and then attach the earpad to the baffle by twisting clockwise.
I love this headphone, but the fact that it is on ear is a turn off for me, my ear is very sensitive, it hurt after a while, other than that the sound is amazing!
They are very comfortable for me as well, but not all heads are made the same.
They are not very sturdy, especially the gimbals, but they more than make up for it by being able to be folded into a sturdy case and occupying less space than seemingly smaller portables that don't fold.
I really urge people habing sibilance problems to try the toiler paper mod; just place a circle of TP over the driver grille under the pads. I'm currently using 3-ply paper with one ply removed, so it is really 2 layers of paper.
I've never noticed even a hint of sibilance with the three pairs I've heard. The highs are smooth to my ears.
I used to think that but now I can literally wear them all day without discomfort. Comfort for me is very very good after a while.
