peteham
- Dec 27, 2007
That amp sounds pretty freakin' cool, but lambskin? Yeech!
I think someone with a good amount of amp experience should buy these and let us know just how good they are so I can formulate my opinion.
Aesthetically, the look is not new. It's basically the Indeed/Bravo amp.
The Project Sunrise has also only been around for, say, 3 months? It's still a bit early to tell whether the happy owners are going to stay happy with it in the long term.
I've been here long enough to know that they wont. Or they will simply stop coming to sites like this, and in that case I salute them.
^ Forgive my ignorance, but regarding line level output: what voltage does an iPod Classic output, when using a LOD?
The bad news is that the Line Out jack on most portable media devices does not solve the output signal level. For example, the above tests showed us that on the Ipod, both the line out jack on the Apple Universal Dock and the Line out cables still put out a miserly signal of around 2 volts. So we still have that problem.
[size=10pt]Eric_C I said it looked like a sculpture, not that it was a new design. That is like saying "aesthetically, every amp that uses an aluminum front panel is not new" but does not mean they do not look different and better than one over the other. After looking at the amps you named, those amps do not look to be of the same quality at all. [/size]
[size=10pt]I found the original Project Sunrise column in another forum where the amp was originally conceived and it looks like people had the first units back in June so not a long time, but more than double the 3 month quote of being out.[/size]
Cheaphifi I listened to the sunrise last week on his 650 headphones and some of my headphones at the inventors place and I did not detect any clipping at all even at levels that hurt my ears, and that was out of a sansa fuze and an emu device? How loud are you trying to play your music? I am a novice to headphones but not to audio so I know what clipping sounds like. If your setting your volume at maximum on your sources, that may be why you are hearing clipping as garbage in = garbage out. I read the entire original threads on sunrise from start to finish which covered a lot of pages. I did not find anyone talking about source issues or clipping except for one person that had some really strange volume tests and comments that did not make much sense but it did not come across like he knew audio very well. No one else had those results?
