Review: RIVA Turbo X High Performance Premium Mobile Bluetooth Speaker – Plus Headquarters Tour
Sep 3, 2016 at 5:04 AM Post #196 of 234
I emailed riva asking if I could buy one through their support email form on their web page.. no response and it's been about 3 days.. heh I also tweeted at their twitter..
Sep 3, 2016 at 5:08 AM Post #197 of 234
If you don't want to wait, then get the universal adapter as mentioned in the previous page.
Sep 3, 2016 at 5:25 AM Post #198 of 234
I was worried about bumping the voltage selector and destroying my riva or losing the little tips, but I guess it's cheap enough I should give it a try.. ordered this one https://www.amazon.com/gp/product/B004I5ERUW/ref=od_aui_detailpages00?ie=UTF8&psc=1
edit: nevermind, a review says the item description is wrong and it doesn't have 19v.  I'll just wait until a knowledgeable user tells me the barrel size or riva support gets back from vacation
Sep 3, 2016 at 11:15 AM Post #199 of 234
You were already given DC barrel size dimensions in the previous page from a fellow TURBO X owner, @salla45.
Not to put words into RIVA's mouth, but, this is the Labor Day weekend for the United States, so I would give it a few more days to give them a chance to respond.
Sep 3, 2016 at 1:14 PM Post #200 of 234
he didn't give the barrel dimensions needed moedawg, he just measured the outside
Sep 3, 2016 at 6:20 PM Post #201 of 234
Sep 3, 2016 at 7:14 PM Post #202 of 234
sorry, what do you mean by barrel dimensions? I measured, using a micrometer, the diameter of the male shaft which enters the power socket hole in the back of the riva. I thought this is what you wanted?
Sep 3, 2016 at 7:33 PM Post #203 of 234
salla oh I meant the inner ring diameter and outer ring diameter, that tells you whether it will fit in the plug...  most are 2.1mm inner 5.5mm outer.
Sep 3, 2016 at 7:39 PM Post #204 of 234
OK sorry, I have a set of calipers somewhere, Ill try and find them tomorrow and give you an idea!
It's definitely 19v DC and 3.42a,  by the way.
Sep 3, 2016 at 7:57 PM Post #205 of 234
Thanks Salla! You rock
Oct 8, 2016 at 12:20 AM Post #207 of 234
I ended up contacting Riva again and got them to sell me an official ac adapter for $30.  I have to say the riva turbo x is the most reliable bluetooth thing I've used.  Very easy to connect to, remembers last device for autoconnect etc.
It's on sale right now for $199 and the S for $149
Oct 25, 2016 at 1:39 PM Post #208 of 234
Any comparisons of the turbo X to the turbo S, I am thinking of pairing it with a echo dot ,over buying a full size echo.
Nov 29, 2016 at 9:07 PM Post #209 of 234
How does the sound / features of this compare to the JBL Xtreme?
The JBL looks more rugged, and more convenient since it can charge via USB rather than an ac adapter. I don't really need the supreme ruggedness though.
Riva is less expensive, and based on some reviews, probably better quality sound.
Anyone have both and willing to offer thoughts?
Dec 4, 2016 at 12:59 PM Post #210 of 234
2017 will probably be a huge yr for wls speakers.
wonder if at the upcoming CES show we'll see more stuff from Peachtree etc
...and a release date on the new Riva wand/festival series.
wish they had a distributor up here in Canada...would love to experience their sound.
