willyvlyminck
- Jul 30, 2012
I did not judge on purpose. I would like to spend some more time with SD4 first.
However, I think it really depends on what you consider musical. For example, I prefer the CE4 over CE6 from Cosmic Ears because the voices sound more romantic to me, whereas other will say they need the bass quantity from CE6.
The SD2 - I might add, I honestly think it is at least as good as the CE4 - has these really beautiful voices. It makes (Jazz) vocals sound amazing. But on the other hand, SD4 will be the preferred choice for more energetic music that needs a little push from the low-end. Say Metal, Electronica,
How does the SD2 compare with the Grado GR10 , as those are also in ears that sounds particulairly well with voices, acoustic (jazz) music, but also with progrock,if well recorded, with the latest Steven Wilson you can clearly hear the bass, on less good recordings the bass is more in the background than let s say the IE80
