I've had this amp for about 2 or 3 years, but the battery dies after about (guessing) a couple of hours. Is there a way to replace the battery in this amp?
I would assume if you could open up the E17 and figure out what model battery is there, then see if you can find that battery (new) somewhere.
At a minimum of work, you would be looking at doing some soldering.
Might try emailing FiiO, see if they can do the battery replacement.
