Username15
- May 2, 2013
Hello, I feel that the stock power cable lacks power for my A5+'s. Should I replace it? If yes, what should I try?
Thanks.
Thanks.
Not money efficient to replace the power cable on speakers in that price range to try to improve sound. If it uses a standard power cable try some 14 awg from monoprice
Thanks.
Also, has anyone used the Nordost Purple Flare power cable and the Audioquest NRG-1? Which sounds better?
