Does anyone know where I can find replacement pads for the Sennheiser HD 599? Sennheiser has discontinued them, and Amazon and Ebay only sell pads for the 598.
It might be that the HD599 and others of the HD500 series use the same pads.
May use different material for the outer covering, but otherwise the same.
