Replacement Pads for Focal Clear, ZMF and Dekoni Foam Too Stiff
Mar 28, 2024 at 9:58 AM Thread Starter Post #1 of 3
bobelton
New York City
I’m trying to find a good replacement pad for my Focal Clears. I’ve already tried ZMF’s and Dekoni’s replacement pads, but they are uncomfortable. I find the foam much thicker/stiffer than in the original pads. I wear these for 4-6 hours a day while at work, so comfort is important. I probably should have just purchased Focal’s own replacements, but I didn’t want to shell out $200 at the time and would like to avoid doing so if I can avoid it. Has anyone found replacement pads with a feel that is close to the original pads?
Apr 9, 2024 at 9:29 PM Post #3 of 3
Cool, I’ll try working them a bit to break them in.
