victorcc
- Feb 18, 2011
[size=small]Hi there,[/size]
[size=small] [/size]
[size=small] I am looking for new pads to replace the damaged ones for my audio technica a1000x and I would need some help.[/size]
[size=small] Does anybody know which pads are compatible? I have read several posts talking about comp/incomp-atibility among different ath models but nothing related to the a1000x. I guess I would be on the safe side buying the ones for the a2000x from audiocubes (http://www.audiocubes2.com/brand/Audio-Technica/product/Audio-Technica_Replacement_Pads_for_ATH-A2000X.html).[/size]
[size=small] As I will buy new pads anyway I was thinking on maybe buying real leather pads like the ones for the w5000 (http://www.audiocubes2.com/category/Headphone+Accessories/product/Audio-Technica_Replacement_Pads_for_ATH-W5000.html) but I need to know if they would be compatible with my cans and also would like your opinion on how the sound would change. I guess I would get less isolation and less bass with the leather ones. What do you think?[/size]
[size=small] Any other option apart from audiocubes?[/size]
[size=small] Cheers.[/size]
